1976 Ford Torino alternator
DCCOLEMAN5
  • 1976 FORD TORINO
1976 Ford Torino
Electrical problem
1976 Ford Torino V8 Two Wheel Drive Automatic
76 ford torino
it is burning up alternators. Initially seems to work intermittenly then completely burns up
My question is this: could it be a result of not having a dash instrument cluster connected (because no indicator light connected) if so, is there any way to fix it without the instrument cluster? (Mine is pretty much destroyed) I bought a replacement cluster, but it was a little different and the wiring apparently is not the same. Since most of the gauges do not work when I connect it
if not the gauge cluster. Do you have any other ideas?
thank you for your help
chandler coleman
Friday, April 17th, 2009 AT 9:10 AM
MIKE H R
  • 3,094 POSTS
How many altinators have you replaced? There could be a short in the wiring by the altinator. Check the wires. I am not much in computers but disconnect the battery and leave it off for a minute then reconnect it. When you watch to see if it has a big spark. That will mean something is sdraining the battery. As far as I know you can drive without a instrument cluster. I have a feeling that there is a short somewhere. Check the wires to see if any get hot. If so inspect them to see if you can find the source.
Friday, April 17th, 2009 AT 10:06 AM
DCCOLEMAN5
  • 10 POSTS
I have replaced 3 or 4. But I read in a couple of different places that even if the indicator light bulb in the dash is blown that the alternator will not work properly. It seems to work at idle but not when rpms reach a certain point
Friday, April 17th, 2009 AT 10:13 AM
MIKE H R
  • 3,094 POSTS
So the altinator does work but just at low speeds. Check the tension on the belt to make sure the idler pulley is keeping it tight enough.
Friday, April 17th, 2009 AT 10:41 AM
