Electrical problem
1976 Ford Torino V8 Two Wheel Drive Automatic
76 ford torino
it is burning up alternators ... initially seems to work intermittenly then completely burns up
My question is this: could it be a result of not having a dash instrument cluster connected (because no indicator light connected) if so, is there any way to fix it without the instrument cluster? (mine is pretty much destroyed) I bought a replacement cluster, but it was a little different and the wiring apparently is not the same ... since most of the gauges do not work when i connect it
if not the gauge cluster ... do you have any other ideas?
thank you for your help
chandler coleman
76 ford torino
chandler coleman
Apr 17, 2009 at 2:06 AM
