Ford Thunderbird High-Speed Shake
OBED
does the transmission mount has anything to do with my car shaking when it reaches high speeds? When servicing the radiator or the cooling system,why does the valve on top of the thermostat housing has to be remove? it says to be remove before servicing the system.
Aug 1, 2007 at 3:37 PM
POET042005
  • 134 POSTS
Usually the transmission mount will not cause vibration unless the bolts are loose, or the car has transfer case for 4x4 cars inwhich your case the car is not 4x4. the most common cause for vibration is due to unbalance tires or a lump in one or more of the tires. Another cause could be inacurate timing. DOse the car run rough when idling
Are you having transmission problems and if so what kind. Also how old are the tires.
hope this will be of some help but before you spend a dollar fill me in on the questions.
Richard
Aug 15, 2007 at 11:37 AM
Suggested Repair
Do not assume the transmission mount is the cause unless its bolts are loose. Check the tires for imbalance or lumps and verify ignition timing before spending money on repairs.
Conversation Summary
The owner of a Ford Thunderbird asked whether the transmission mount could cause shaking at high speed and why a valve on the thermostat housing must be removed before cooling-system service. The expert said a transmission mount rarely causes vibration on this non-4x4 car unless the bolts are loose. Unbalanced or lumpy tires and inaccurate timing were identified as more common causes. The expert asked about idle roughness, transmission symptoms, and tire age before recommending further spending. The cooling-system valve question was not answered.
