1997 Ford Thunderbird Won't Communicate
JOELCT
Hi Everyone. 1997 Ford Thunderbird, 166,000 miles on a well-running 6-cyl engine. I have passed 8 straight inspections (Texas) with no trouble. This year, the ispector failed me because: "Your car's computer will not communicate with the State's computer." Maybe they're having a fight or something, I don't know, but the car is running perfectly, so I know the computer works. Does anyone know what this means?
Aug 1, 2007 at 5:25 AM
POET042005
  • 134 POSTS
Have the car checked for codes, computer maybe receiving error codes from a sensor stating a problem.
But before you do this Is the check engine lite staying on once the car has been running for a few minutes. Thats usually an indication that the computer is receiving error code(s).
Aug 15, 2007 at 11:42 AM
Suggested Repair
Scan the vehicle for diagnostic trouble codes and confirm whether the check engine light stays on after the engine has been running for a few minutes, which can indicate a sensor fault the computer is detecting.
Conversation Summary
The owner of a 1997 Ford Thunderbird with 166,000 miles failed a Texas inspection because the car's computer would not communicate with the state computer, although the car runs well and had passed prior inspections. The expert advised checking for stored codes and whether the check engine light remains on after startup.
