1995 Ford Thunderbird Won't Stay Running
YYVTT1211
ford thunderbird 1995 400,000 car will start but will not stay running it feels as if it is not getting any fuel when i unplug the fuel shut off switch in trunk it will stay running plug it back up car shuts off changed fuel filter if car sits over night will run until it get hot it seems like it is sucking air
Feb 26, 2006 at 9:39 AM
PEPPERMRJ
  • 1,158 POSTS
400,000 miles? :shock: Original engine?
Sounds like the fuel shut off switch needs replaced.
The fuel pump's electric motor also sounds if it is dying.
Good luck and let us know. :)
Feb 26, 2006 at 11:18 AM
JPAM
  • 307 POSTS
dang time to retire it.. its lived a full life. :lol:
Feb 26, 2006 at 12:34 PM
Suggested Repair
Replace the trunk fuel shutoff switch. Also check the fuel pump electric motor, which may be failing given the high mileage and heat-related stalling.
Conversation Summary
A 1995 Ford Thunderbird with about 400,000 miles starts but will not stay running and feels like it is not getting fuel. Unplugging the trunk fuel shutoff switch lets it run, while plugging it back in shuts the engine off. The fuel filter was already replaced, and after sitting overnight it may run until it gets hot, as if it is sucking air. An expert recommended replacing the fuel shutoff switch and noted the fuel pump motor may also be dying.
