Fuse for fuel injector burns
FORD THUNDERBIRD
THUNDERBIRDGUY
I Have a ford thunderbird 4.6l V8. and i bought it from a used dealership. Well the fuse for the fuel injecter keeps burning up. it gets melted....Should i use a higher amp fuse....Any help thanks[/b][b:796999a25a][size=18:796999a25a][/size:796999a25a][/b:796999a25a]
Jul 6, 2006 at 12:28 AM
TAURUSWHEEL
  • 718 POSTS
Are you using the correct size fuse to start with??? If yes, do not use higher amperage, may exacerbate whatever problem is causing the fuse to fail, may start a fire.. take it back where you bought it, tell them to fix it..
Jul 6, 2006 at 2:19 PM
