1993 Ford Thunderbird Keyless Entry
CATEPILLAR682
I recently purchased a 1993 Ford Thunderbird which has a keyless entry system. I quite frankly do not trust the people I purchased the vehicle from and would like to disable/remove the system without removing the fuse.
Apr 16, 2007 at 1:08 PM
TAURUSWHEEL
  • 718 POSTS
Find the keyless entry module, usually located on the package tray in the trunk and unplug, then check for no operation, it will also disable the lamp-on system thru the door handles I think..
Apr 16, 2007 at 2:06 PM
Suggested Repair
Locate the keyless entry module, usually on the package tray in the trunk, and unplug it. Confirm the system no longer operates. This may also disable the door-handle lamp-on feature.
Conversation Summary
The owner of a 1993 Ford Thunderbird wants to disable the keyless entry system without removing the fuse. The expert recommends unplugging the keyless entry module on the trunk package tray and verifying that it no longer works, noting that the door-handle lamp-on system may also be disabled.
