1995 Ford Thunderbird Blower Cuts Out
Suggested Repair
There is no blower relay on this system. Power runs from the blower switch through the blower resistor to the motor, and high speed bypasses the resistor. Because the blower cuts out completely at any speed, replace the blower resistor first; if the problem remains, check the blower switch next.
Conversation Summary
The owner of a 1995 Ford Thunderbird reported that the blower turns on and off at random regardless of fan-speed setting, with no need to jiggle anything. When it is on, the speed settings work normally, and when it is off it is completely off. The expert explained that there is no blower relay and that power goes from the switch through the resistor to the motor, with high speed bypassing the resistor. The expert said resistor failure is much more common than switch failure and recommended replacing the resistor first.
