1995 Ford Thunderbird Hot Stall
STCKCAR43
i have a 95 thunderbird with 160,000 miles and an automatic 4.6 v8..after the car reaches operating temp the idel starts to surge and after a afew min it stops runng like the switch has been shut off . after it stops running it wont start untill it cools down ....we replaced all of the o2 sensers ...
Sep 11, 2007 at 4:18 PM
  • 75,988 POSTS
[quote:4c72d2756e="stckcar43"]i have a 95 thunderbird with 160,000 miles and an automatic 4.6 v8..after the car reaches operating temp the idel starts to surge and after a afew min it stops runng like the switch has been shut off . after it stops running it wont start untill it cools down ....we replaced all of the o2 sensers ...[/quote:4c72d2756e]
Investigate the TPS and the idle speed control-that cehecks out -do a fuel pressure check and report ASAP with your findings,
Sep 11, 2007 at 6:24 PM
Suggested Repair
Check the throttle position sensor and idle speed control. If those test good, perform a fuel pressure check and report the results.
Conversation Summary
A 1995 Ford Thunderbird with a 4.6 V8 surges at idle after reaching operating temperature, then shuts off and will not restart until it cools. All oxygen sensors were already replaced. The expert advised checking the TPS and idle speed control, then performing a fuel pressure test if those check out.
