How does one get to the thing ? Its under a piece of steel & access from down under is blocked too from steel cross members and plating
Any Ideas Please ?
Thanks
James
Safely raise and support the front of the car, then inspect the front of the rack and pinion for the leaking high-pressure line. Try to reach the fitting before disassembly. If access is blocked, slightly raise the engine after loosening the motor mounts.
The owner of a 1991 Ford Thunderbird replaced a power-steering hose but still found a leak below the lower connection, from a metal line running under the motor mount toward the steering sector. Access was blocked by steel and crossmembers. The expert identified the line as going to the rack and pinion and advised raising the car on jack stands, inspecting the front of the rack, and loosening the motor mounts to raise the engine slightly only if the fitting cannot otherwise be reached. The owner then asked whether undoing a motor mount is necessary, but no further reply confirmed it.
