1997 Ford Thunderbird Coolant Leak
BARBMCKOWN
97 Ford Thunderbird 156,000 miles. Leaking rusty water...not sure from where?? I thought it was the water pump...but would that water be rusty??? Now I am thinking that it may be the Radiator. Car still running good...no hesitation...Just have to keep filling the coolant back up.
May 18, 2006 at 8:19 AM
LOSONE
  • 1,616 POSTS
If the coolant has never been changed every 30K miles it will be VERY rusty!
A water pump or a heater bypass is a common leak. Have it pressure tested before you have a failure.
May 18, 2006 at 9:53 AM
Suggested Repair
Have the cooling system pressure tested before a failure. A water pump or heater bypass is a common leak source. Rusty coolant often means it has not been changed about every 30,000 miles.
Conversation Summary
The owner of a 1997 Ford Thunderbird with 156,000 miles reports a rusty coolant leak of unknown origin and must keep adding coolant. The car still runs well. The expert says neglected coolant changes can make coolant very rusty, notes that a water pump or heater bypass is a common leak, and recommends a pressure test before a failure.
