1991 Ford Thunderbird Power Steering Leak
BONDJAMESBOND
Had a common hose leak I thought , the one on the side as you look down upon the P/S pump from the drivers side. So I replaced it and found the leak was still there just below the lower hose end connection point; From a metal line under the motor mount going to the sector. Can't grt my hand in there nor the spanual, very tight indeed.
How does one get to the thing ? Its under a piece of steel & access from down under is blocked too from steel cross members and plating
Any Ideas Please ?
Thanks
James
Aug 2, 2007 at 3:28 PM
POET042005
  • 134 POSTS
Hi there well I believe the hose you are talking about gose to the rack and pinion. Jack the car in the front and secure it on jack stands. crawl under and look at the front of the rack Its been awhile since I've looked at one of these but I believe that its visible if not you may need to slightly jack the motor in order to get to it which may require loosening the two motor mounts. But before you take anything apart make sure you locate it on the rack and if you can reach it first.
Hope this helps let me no what happens.
Aug 16, 2007 at 1:13 AM
BADHABIT
is it necessary to undo motor mount to install hi-pressure powersteering line?
May 24, 2012 at 8:29 PM
Suggested Repair
Safely raise and support the front of the car, then inspect the front of the rack and pinion for the leaking high-pressure line. Try to reach the fitting before disassembly. If access is blocked, slightly raise the engine after loosening the motor mounts.
Conversation Summary
The owner of a 1991 Ford Thunderbird replaced a power-steering hose but still found a leak below the lower connection, from a metal line running under the motor mount toward the steering sector. Access was blocked by steel and crossmembers. The expert identified the line as going to the rack and pinion and advised raising the car on jack stands, inspecting the front of the rack, and loosening the motor mounts to raise the engine slightly only if the fitting cannot otherwise be reached. The owner then asked whether undoing a motor mount is necessary, but no further reply confirmed it.
