2002 Ford Thunderbird Ignition Coils
NINETTE
  • 2002 FORD THUNDERBIRD
Engine Performance problem
2002 Ford Thunderbird V8 Automatic 122000 miles
I had 2 ignition coils replaced by Ford at a cost of almost $900. Now the car needs more coils replaced and I just can't justify a $1000 bill for 2 more coils each year until they are all replaced. Can I do this work myself? I know absolutely nothing about cars, although I can change a tire. The only mechanic I know is my brother, however he lives 800 miles away.
Tuesday, August 18th, 2009 AT 8:31 AM
WINEBURGER
  • 82 POSTS
What code is coming up.
Tuesday, August 18th, 2009 AT 8:37 AM
NINETTE
I only have the receipt for the work and as far as I can tell there isn't an indication of a code number. However under "description" is printed SP 468 and DG 529. Ford replaced #6 and #7 in January, in April it started misfiring again.
Ninette
Tuesday, August 18th, 2009 AT 9:01 AM
WINEBURGER
  • 82 POSTS
Did you change all the spark plug at some point
Tuesday, August 18th, 2009 AT 9:06 AM
NINETTE
Not that I am aware of. I don't believe the car has ever been tuned-up. It has been worked on by one Ford Dealer since I bought it in 2002. They did the scheduled warranty maintenance and then any other issues I may have had in the past.
Tuesday, August 18th, 2009 AT 1:37 PM
WINEBURGER
  • 82 POSTS
Platinum plugs usually last around 100000 miles the start going out I would replace plugs for cylinder missfire codes not coils
Tuesday, August 18th, 2009 AT 2:14 PM
NINETTE
Thank you for your rapid response. I'll try replacing the spark plugs first. Now you wouldn't know a great spagetti sauce recipe. :-) Thanks again
Tuesday, August 18th, 2009 AT 3:08 PM
WINEBURGER
  • 82 POSTS
Your welcome
Tuesday, August 18th, 2009 AT 3:14 PM
