1995 Ford Thunderbird air bags
1995 FORD THUNDERBIRD
BOYD
Computer problem
1995 Ford Thunderbird V8 Two Wheel Drive Automatic
I am using the engine and tranny from a 95 thunderbird v-8 for a project vehicle. The airbags were deployed in the vehicle (VERY minor damage!) and now the vehicle will not power up at all. I assume this is an intentional cut-off of some type. question is, what do I reset and where is it? By the way, the project is a '63 landcruiser fj-40. I will not be needing airbags for that.
Jul 19, 2008 at 5:57 AM
2CARPRO JACK
  • 11,533 POSTS
Ive never heard of that before, the SRS (air bags) and the engine management are two seperate systems. Look at teh fusible links at the battery/starter solenoid, there may be one or two burnt. Is there any power to the interior of the car (fuse panel)?
Jul 20, 2008 at 1:37 AM
BOYD
dome lites, door chime and gauges. I'm now wondering if this a factory anti theft system thats tripped. If so does that need to stay with the "brain" when I pull the motor?
Jul 20, 2008 at 8:18 AM
2CARPRO JACK
  • 11,533 POSTS
Pretty sure that is in the BCM, the PCM is for the engine.Just wouldnt crank?
Jul 21, 2008 at 12:31 AM
