1994 ford thunderbird SRS 4.6 V-8
PHOENIXDRAKE
MY CAR WAS RUNNING FINE UNTIL 2 WEEKS AGO. IT BEGAN SHUTTING OFF IMMEDIATELY AFTER I STARTED IT. AT FIRST I THOUGHT IT WAS A FUEL PROBLEM, POSSIBLY FUEL PUMP OR FILTER,BUT AFTER I CHANGED THE SPARK PLUGS THE CAR PERFORMED GREAT UNTIL THE NEXT DAY. THE SAME PROBLEM RE-SURFACED; IT STARTS EVERYTIME I CRANK IT BUT SHUTS OFF AFTER A FEW SECONDS. I HAVE TO KEEP THE ENGINE REVED UP JUST TO KEEP IT GOING AND SOMETIMES THAT DOES'T WORK. THE FEW TIMES I DID GET IT TO RUN RIGHT I WOULD BE AT A STOP LIGHT , THEN ALL OF A SUDDEN I WOULD LOSE POWER, BY PUMPING THE GAS PEDDLE IT WOULD GO BUT WHEN I SLOW DOWN THE CAR SHUTS OFF, THEN I HAVE TO START,PUT IN GEAR FAST BEFORE IT TURNS OFF. PLEASE TELL ME MY PROBLEM IS SIMPLE?
Feb 19, 2007 at 9:04 AM
KIN CHAN
  • 453 POSTS
sounds like u've got vacumm leaks.....any shop with a smoke machine can fix it...u don't quiet sounds like u have basic knowledge of internal combustion gasoline engine...u better off finding a reputable shop and fix it...cuz thats a little bit of safety concern if u are not familiar under the hood during check while the engineis running ...email me if u still wanna pursuit repaiing it by urself
Feb 19, 2007 at 2:03 PM
