1995 Ford Thunderbird
J.PHILLIPS
  • 1995 FORD THUNDERBIRD
Engine Mechanical problem
1995 Ford Thunderbird 6 cyl Two Wheel Drive Automatic
the driver side exhaust manifold is glowing read.
could it be my throttle positioning sensor?
any advice would be help full thank you
Friday, October 22nd, 2010 AT 8:33 PM
Probable causes of an engine running rich are as follows:
1. Excessive fuel pressure can be cause by restricted fuel return line or defective fuel pressure regulator.
2. Defective Oxygen Sensors.
3. Leaking injectors and fuel pressure regulator.
4. Coolant temperature sensor out of calibration.
5. Restricted air intake system.
Sunday, October 24th, 2010 AT 11:22 PM
