1995 Ford Thunderbird engine runs great then faulters
154,000 MILES • V8 • 2WD • AUTOMATIC
TLLFTZ568
engine faulters occasionally whether accelerating or going at a consistent speed. Transmission guy said it had nothig to do with the transmission. Engine actually shuts down occasionally.
P0320 CODE) IGNITION/DISTRIBUTOR ENGINE
SPEED INPUT CIRCUIT MALFUNCTION
Could it be any of these?
1 - FORD HAS A BULLETIN OUT ON THIS: TSB #98-23-10 DATED 11/23/98, MASS AIR FLOW (MAF) - SENSOR CONTAMINATION.
2 - THE POWER TRAIN CONTROL MODULE FOR FAULT CODES
3 - OXYGEN SENSOR
4 - COIL – LEFT & RIGHT
Feb 8, 2010 at 11:42 PM
RACEFAN966
  • 5,029 POSTS
With this code I would check for good connections at the coil check spark plug wires for good connections. As for you mass air flow question get mass air flow cleaner and remove it and spray it out. You don't have a two way radio in this car do you? If so this will cause the code to come up too.
Feb 9, 2010 at 12:59 AM
