1994 Ford Thunderbird used too much oil
1994 FORD THUNDERBIRD
GSTONETALKER
Engine Mechanical problem
1994 Ford Thunderbird V8 Two Wheel Drive Automatic 140k miles
a quart of oil used in one thousand miles. no leaks i can see. is it possible to burn oil and spark plugs still be clean and dry ? just bought car and had wal mart change oil. not sure if i checked oil since they changed or not. if the plugs are clean, and there are no leakes, what would be wrong with the engine ?
Jan 10, 2010 at 3:27 PM
If its using oil and going into the cylinders you'll see it-if its not there must be leaking externally. Your option here is get the engine compression checked out to find out where Valves or Rings
Jan 10, 2010 at 7:28 PM
