Will start and drive then cut off
CAROLINAGIRL3
  • 6 POSTS
Our car was in an accident a little over a year ago but still drove fine. Here recently for some reason it will start and drive about a mile up the road then cut off. Some people have told us that it could be the fuel pump but he doesn't think that's the problem.. We don't really know what's wrong with it. Please help....
Jun 22, 2013 at 5:25 AM
CJ MEDEVAC
  • 11,000 POSTS
WHEN IT DOES THIS.......WILL IT FIRE RIGHT BACK UP?
ARE YOU CAPABLE OF SOME SIMPLE TESTING, WHEN IT DOES DIE?
ELABORATE ON WHAT IT DOES/ SKIP/ JUMP/ SPUTTER/......OR JUST AN INSTANT DEATH?
THE MEDIC
Jun 23, 2013 at 1:42 PM
CAROLINAGIRL3
  • 6 POSTS
No, it doesn't fire back up but it tries to and then it can take anywhere from 5 mins to a couple of days to get it started again. Could it be the fuel pump?
Jun 24, 2013 at 1:41 AM
CAROLINAGIRL3
  • 6 POSTS
It's a smooth quite shut off.. The only reason you realize it shuts of is bc the dash lights come on and you lose speed.
Jun 24, 2013 at 1:44 AM
CAROLINAGIRL3
  • 6 POSTS
Smooth instant death
Jun 24, 2013 at 1:45 AM
CJ MEDEVAC
  • 11,000 POSTS
I DON'T KNOW WHAT YOU HAVE TRIED
WHEN IT GOES DEAD----IMMEDIATELY SNATCH THE INTAKE AIR SNOUT OFF OF THE THROTTLE BODY AND SHOOT ABOUT A 2 SECOND BURST OF STARTER FLUID INTO THE THROTTLE BODY---SHOVE THE SNOUT BACK ON AND GIVE IT A TRY............DOES IT RUN/ TRY TO RUN BETTER THAN BEFORE?.....IF SO, THIS COULD BE A FUEL ISSUE
HERE'S ANOTHER ONE TO TRY---THIS ONE IS TO SEE IF YOU HAVE SPARK, WHEN IT DIES
ONE OF THESE ARE VERY HELPFUL
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_in-line-spark-tester-mountain_22989180-p?searchTerm=spark+tester
SIMPLY REMOVE THE PLUG WIRE OFF OF A SPARK PLUG. THEN HOOK THIS PUPPY TO THE PLUG WIRE---THE OTHER END HOOKS BACK ONTO THE PLUG.......IF YOU HAVE "FIRE" A LIGHT LIGHTS UP IN THE TESTER. THIS KINDA DEVICE WILL KEEP YOU FROM BEING SHOCKED (LIKE WHEN DOING IT THE OLD WAY) DOING THIS IN THE SHADE OR AT NIGHT, LET'S YOU SEE A SPARK BETTER
IS THE CHECK ENGINE LIGHT ON?
DOES THE CHECK ENGINE LIGHT "VERIFY" IT WORKS, WHEN YOU GO TO CRANK IT UP?
N OR S CAROLINA?
THE MEDIC
Jun 24, 2013 at 6:10 AM
CAROLINAGIRL3
  • 6 POSTS
Yes, one time the car won't start so he did remove that from the throttle body one time when it wouldn't crank and sprayed it and the car started. After it started he had to keep spraying it to keep it started. He said sometimes he will have the ignition on and that he will check to see if the engine has fuel and it does that other times it won't show any signs of fuel. We live in NC.
Jun 25, 2013 at 6:30 AM
CJ MEDEVAC
  • 11,000 POSTS
SHOWING YOU AN INEXPENSIVE FUEL PRESSURE TEST GAUGE (SOME STORES RENT THEM/ LOAN THEM OUT WITH A DEPOSIT
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_fuel-pressure-test-kit-otc_28031640-p?searchTerm=fuel+pressure+test+gauge
THIS IS HOW I BUY STUFF---ADVANCE AUTO PARTS IS IN YOUR AREA! (I'M DOWN HERE IN S.C.) "A124" WAS WORKING YESTERDAY (HAS BEEN FOR A LONG TIME)---IT WILL SAVE YOU $10 ON THIS PURCHASE ALONE...OTHER STUFF LATER!....SEE HOW THIS WORKS IN THE LINK BELOW
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
REGARDLESS---THIS IS WHAT I WANT YOU TO DO
1ST......GET IN THE CAR AND TURN ALL RACKET MAKERS OFF, WAIT FOR THE TRAIN TO PASS AND THE TRAFFIC NOISE TO STOP, HUSH UP THE YOUNGINS ................THEN TURN THE KEY TO "ON" (NOT START) DO YOU HEAR A 1-2 SECOND "HUM" OF THE FUEL PUMP?
THIS WILL "HUM" EVERY TIME YOU TURN THE KEY TO "ON"...........................................................UNLESS NO POWER IS REACHING THE PUMP....OR THE PUMP IS JUST PLAIN OLE BAD (OR GETTING THERE)
WHEN IT WILL NOT START.......CALM DOWN.....TURN THE KEY TO "ON"..........DO YOU HEAR THE "HUM" OR NOT????........WE WANNA KNOW IF THE PUMP IS OPERATING OR NOT, WHEN IT WILL NOT START
OTHER THINGS COULD BE WRONG----THIS IS A STARTING POINT........RESULTS?
A FUEL PRESSURE TEST WOULD BE A NICE TOUCH TOO!
ALSO GIMME THE EXACT NOMENCLATURE OF YOUR CAR AND THE ENGINE SIZE.....IF NEED-BE, I HAVE ACCESS TO "MITCHELL I", I CAN PULL UP DIAGRAMS OF WHERE FUSES/ RELAYS AND OTHER STUFF IS FOR YOUR CAR, SHOULD WE FIND THAT WE NEED THEM
MY MOM AND DAD HAVE AN '86 T-BIRD, BOUGHT NEW, AND STILL HAVE IT, YEARS AGO I PULLED MY HAIR OUT TRYING TO LOCATE THE RELAY TO THE FUEL PUMP.......IT WAS SORTA WELL HIDDEN IN THE TRUNK.....THE REPAIR MANUAL DID NOT SHOW IT.......I DID NOT HAVE A COMPUTER, MUCH LESS MITCHELL I !
YOUR TURN
THE MEDIC
Jun 25, 2013 at 12:41 PM
CAROLINAGIRL3
  • 6 POSTS
Okay... This is what happened... He turned the car to the on but did not to start it... It did the hum.. Twice and then started but when he turned the key and didn't hear the hum.. The car wouldn't start. He has a fuel pump that a friend gave him but it's for a 94 Ford Pickup...He would like to know if... The shut off switch in the trunk would have anything to do with it shutting off the fuel pump where it won't start.
Jul 7, 2013 at 9:57 AM
CJ MEDEVAC
  • 11,000 POSTS
Twice and then started but when he turned the key and didn't hear the hum.?????????????????
IT TURNED OVER AND BUSTED OFF (AND RAN)??????
"HUM" MEANS THE FUEL PUMP IS/WAS RUNNING
HOW 'BOUT MR. FUEL FILTER......HAS HE EVER BEEN CHANGED?
THE FUEL PRESSURE TEST?
I KNOW YOU WANT ME TO TELL YOU TO POUR SOMETHING IN.....AND IT'LL ALL BE BETTER.......DIAGNOSING DON'T WORK LIKE THAT.........GOTTA HAVE STUFF TO "REASON"/ "COMPARE" WITH
SOMEBODY NEEDS TO DO THE TESTING................I'M WAY DOWN HERE!
STILL NO WORD ON EXACT NAMEAGE OF CAR OR ENGINE SIZE....I AIN'T ABLE TO LOOK UP "JUST" YOUR CAR WITH OUT IT..............SORTA NOT GONNA GET EVERY DIAGRAM FOR THE '94 T-BIRD MODELS AND ALL OF THEIR ENGINE VARIATIONS (TAKING LIKE FOREVER) THEN LETTING YOU PICK YOURS OUT.....I NEED COMPLETE INFO ON YOUR CAR!
WHEN IN DOUBT OF A "CAR PART SWAP"------I GO TO ADVANCE AUTO PARTS . COM AND LOOK UP THE PART FOR EACH ONE-------IF THE PART NUMBERS ARE THE SAME...............IT WILL WORK!!!!.......IF NOT, IT'S DOUBTFUL
I DID NOT LOOK UP THE TRUCK PUMP, I'LL LET Y'ALL TRY IT OUT ON THE QUESTIONABLE PUMP
THE SWITCH IN THE TRUNK IS DESIGNED TO KILL THE FUEL IN A WRECK----RESET IT IF IT HAS BEEN TRIPPED
YOU-UN-ES TURN
THE MEDIC
Jul 7, 2013 at 12:49 PM
