Do you have the regular or supercharged engine?
I have the regular V6 and had some problems after start up, the car would stall and almost stop until the engine was warm. After I checked a lot of things I found out that the dipstick from the transmission wasn't all the way down (a mechanic from eazy-lube aparently didn't pull it all the way back). After I put it back, everything was OK. Little things make big difference. I have some white smoke coming from the exhaust too from time to time. Doesn't seem to be problem, I have 125000 Miles on it though. I also had the idle controler replaced one time, I heard it's a problem on this model.
SPONSORED LINKS
Wednesday, February 13th, 2008 AT 11:03 AM
