1988 Ford Thunderbird Engine won't start
FORDTBIRD34002
  • 8 POSTS
Electrical problem
1988 Ford Thunderbird V8 Two Wheel Drive Automatic 213k miles
Engine turns over. I connected a test light from the red wire of the injector to the positive battery terminal, and turned car over. The test light would not light, indicating that there is something wrong with that circuit, what I do not know. I have replaced the ICU along side the dist, I do have spark. What is the problem?
Thanks
Sep 14, 2008 at 7:32 AM
  • 75,988 POSTS
Stick the test light probe into the red wire socket of the harness and ground the other end-do you have power?
Sep 14, 2008 at 7:41 AM
FORDTBIRD34002
  • 8 POSTS
yes, I have power at the red wire, I also hooked the test light to the white wire, and hooked it to the pos battery terminal, cranked the car, the light did not light.
Sep 15, 2008 at 3:30 AM
  • 75,988 POSTS
Test the PCM injector ground driver/s
Sep 15, 2008 at 7:04 AM
FORDTBIRD34002
  • 8 POSTS
I checked the ground for this, if it is near the ignition coil, then this ground was good.
Sep 15, 2008 at 10:48 AM
  • 75,988 POSTS
The injector/s ground drivers are integrated in the computer.
Sep 15, 2008 at 10:49 AM
FORDTBIRD34002
  • 8 POSTS
Is there any way to check the computer?
Sep 15, 2008 at 10:52 AM
  • 75,988 POSTS
You need to bring it in and get it tested or swap for a known good one and see what happens.
Sep 15, 2008 at 10:55 AM
FORDTBIRD34002
  • 8 POSTS
Ok, thanks for your help, I will just have to get another one because I don't live in the USA. I will ask the local Ford dealer if he can test it, but I doubt he can.
Sep 15, 2008 at 11:28 AM
