1993 Ford Tempo Speedometer Cable Fix
SUSANB82
I need to replace a speedometer cable on a 1993 ford tempo could you please send my instructions on how to do this.
May 12, 2006 at 11:13 AM
LOSONE
  • 1,616 POSTS
It isn't that complicated. Buy a new cable and housing.
Unscrew the cable from the transmission first. Remove all clamps that are on the fire wall and frame. The cable housing must be free so you can remove the instrument cluster.
Slide the cluster out so you can see the speedometer housing on the back
The cluster has a tricky clip on the housing.
R&R the housing.
There are no good instructions short of a shop manual which we don't have.
Good luck
May 13, 2006 at 7:13 AM
Suggested Repair
Replace the speedometer cable and housing. Disconnect the cable at the transmission, remove firewall and frame clamps so the housing is free, slide the instrument cluster out, release the clip on the speedometer housing, and remove and replace the housing. A shop manual is recommended for the cluster clip details.
Conversation Summary
The owner asked how to replace the speedometer cable on a 1993 Ford Tempo. The expert said to buy a new cable and housing, unscrew it at the transmission, free all clamps, slide the cluster out, and remove and replace the housing after releasing a tricky clip. They noted a shop manual is needed for fuller instructions.
