1994 Ford Tempo idler arm pulley replacement
1994 FORD TEMPO
OSOMENDEOLA
Engine Mechanical problem
1994 Ford Tempo 4 cyl Front Wheel Drive Automatic
How do I replace the idler arm pulley?
Nov 14, 2008 at 7:42 PM
FIXITMR
  • CAR REPAIR CONTRIBUTOR
  • 9,990 POSTS
if you are referring to the serpentine belt then remove belt and take mounting bolts out of idler assembly and remove.i did mine by removing front wheel and plastic/rubber guard of inner fender and reaching bolts that way.slightly difficult but doable.
Feb 13, 2009 at 8:12 PM
