1994 Ford Tempo harmonic balancer
SKULLGUY
  • 1994 FORD TEMPO
Engine Mechanical problem
1994 Ford Tempo 4 cyl Front Wheel Drive Automatic
how can I change the harmonic balancer without removing the motor?
Thanks
Wednesday, January 20th, 2010 AT 4:50 PM
FIXITMR
  • 9,990 POSTS
You can get to it from behind tire. Might be a plastic cover to remove. Cant recall if you have to remove motor mount though to drop it down by using jack under oil pan? Have fun!
Monday, February 1st, 2010 AT 2:26 AM
