1993 Ford Tempo removal of harmonic balancer
BUTCH900
Engine Mechanical problem
1993 Ford Tempo 4 cyl Front Wheel Drive Automatic
need to know what needs to be removed from engine in order to lower engine far enough to have full acsess to harmonic balancer
Aug 10, 2008 at 5:16 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:9bc210524c="butch900"]Engine Mechanical problem
need to know what needs to be removed from engine in order to lower engine far enough to have full acsess to harmonic balancer[/quote:9bc210524c]
You will have to remove the engine mount at front of engine. Just make sure you have a jack, floor jack works easier, to raise and lower the engine.
Aug 10, 2008 at 5:43 AM
