1993 Ford Tempo Windows
1993 FORD TEMPO
115,000 MILES • 4 CYL • FWD • AUTOMATIC
DINOMAN58
Hi, I have a '93 Ford Tempo with power windows and my uncle gave me the car about 2 years ago, and the driver side front widow does not work. It wants to work but I have to push it to go down, and then it sort of works on the way up, but I have to help it finish. What might be the problem and how can I fix it?
Mar 6, 2010 at 5:57 PM
FIXITMR
  • 9,990 POSTS
if the window is tracking ok then it's probably the thermal overload in the motor is bad. you can remove motor and disassemble and bypass it. or just junkyard another motor.
Mar 8, 2010 at 4:48 PM
