1993 Ford Tempo distributor - removal
1993 FORD TEMPO
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALEXCANDILAS
I'm trying to remove the distributor in order to replace the ignition control module. I got the cap off and can't the bolt to loose the distributor shaft to pull it out. So, my question is how do I remove the distributor
Thank You.
Nov 19, 2009 at 6:19 AM
MERLIN2021
  • 17,250 POSTS
First before you remove it, put the rotor on it if you took it off, then scribe a mark to the block to reset it when your done installing the distributor. There is a hold down bolt next to the distributor, remove it and the hold down fork, then just keep twisting and pulling, WD-40 can help. There is a tool for the TFI module, and most of the time the module can be removed without taking the distributor off...
Nov 19, 2009 at 6:34 AM
