1993 Ford Tempo
GEOFISH40
  • 1993 FORD TEMPO
1993 Ford Tempo 6 cyl Front Wheel Drive Automatic
the car will start and run, but when you turn it off and try to restart it, it cranks but no fuel pump sounds.
let it sit overnight and it starts.
any ideas?
Wednesday, June 16th, 2010 AT 12:59 AM
FIXITMR
  • 9,990 POSTS
Could either be the fuel pump relay or the pump itself. Also check for spark! If not spark problem do search of tempo forum for "fuel" and do some reading to get a better idea about problem and solution.
Wednesday, June 16th, 2010 AT 1:15 PM
