Calipers will be replaced. I had decided this before asking the question, but was wondering if the heat being generated could be from anthing else, before going ahead. Thanks for the comments, and I will let you know if this solves the problem.
The disc appears to be ok, ie not warped. But their is some discoloration. Is this a problem? Disc needs replacing?
Thanks for the comments, as it turns out as suspected it was the Calipers.
I was concerned with the slight discoloration of the Disks, but I clean them up and they seem to be working fine!
Thanks to all those who submitted comments(jeepfan and fixitmr). I don't know how these points work? How do I get points? How many points to give if comment was helpful? I gave point to the fellow that was first to suggest it was probably the calipers.
Thanks again,
Chris
Saturday, October 10th, 2009 AT 12:08 PM
