Engine Mechanical problem
1989 Ford Tempo 4 cyl Two Wheel Drive Automatic
Where do you find the fuel pump on this vehicle?
Thursday, September 16th, 2010 AT 6:23 PM
MECHANIC
The fuel pump is in the fuel tank
SPONSORED LINKS
Thursday, September 16th, 2010 AT 6:45 PM
FIXITMR
MECHANIC
It's located right under the hump in the middle when you remove back seat. I usually cut a hole with chisel about 8-10" in that area. Then when I finish pump change I make a cover ou of sheet metal to put over hole usuing calk to seal it. However if tank is very rusty I remove it instead to clean and tar coat to stop rust.
