1993 Ford Tempo driverside rear wheel bearings
1993 FORD TEMPO
23,600 MILES • 4 CYL • 2WD • AUTOMATIC
MIKEMCLEOD32
how do i find the right inside bearing to fit on my spindle,iv bought one froom napa and turned out it was too small. bought a hub from a local junk yard and it was too small do i need to by one for a 94 model ?
Feb 22, 2009 at 8:47 AM
FIXITMR
  • 9,990 POSTS
is this a front or rear bearing?you say drivetrain so it seems you mean front?front wheel bearing/hub?you dont have a 4 wheel drive model do you?if it is a normal rear wheel bearing then what you are stating dont make sense?either they both gave you the wrong part or something else is funny?as far as i am aware their is only 1 size wheel bearing for the rear on all tempos?except the 4 wheel drive model which is different.strange,online parts sources list a 94 but dont show a part(wheel bearing).
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Feb 22, 2009 at 5:16 PM
