2000 Ford Taurus Wipers Not Moving
SHADOWSEVEN
How easy would it be for me to check the wiper motor assembly on a 2000 Ford Taurus? Where should I look? The blades stopped working and I can hear the motor attempting to move the blades, so the motor itself and the fuse must be ok. Is there a belt or something that could have broken that would make the blades not move?
Mar 15, 2007 at 2:27 PM
TAURUSWHEEL
  • 718 POSTS
Check the linkage, you may have to remove some of the cowling to access it, hopefully it's in there somewhere.
Mar 15, 2007 at 4:06 PM
SHADOWSEVEN
Do you think the assembly would be accessed through the dashboard, or betweeen the hood and windshield?
Mar 17, 2007 at 1:26 PM
Suggested Repair
Inspect the wiper linkage under the cowl. Remove some of the cowling between the hood and windshield to access it; a disconnected or broken linkage can stop the blades even when the motor runs.
Conversation Summary
On a 2000 Ford Taurus, the wiper blades stopped moving while the motor could still be heard trying to operate them, so the motor and fuse appeared fine. The owner asked whether a belt had broken and where to access the assembly. The expert advised checking the linkage and removing some cowling to reach it.
