couple of wiper problems
ANGIE728
Ok I have a 92 Taurus with about 196000 miles. The wipers are messed up- they work fine in low or high position but do not work at all in intermitittent. They stop in the up position and they do not wash the windshield. When I push the button on nothing happens. I think I need a new motor- just want to make sure before I spend the money.
Nov 28, 2007 at 8:38 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e97ea663e7="angie728"]Ok I have a 92 Taurus with about 196000 miles. The wipers are messed up- they work fine in low or high position but do not work at all in intermitittent. They stop in the up position and they do not wash the windshield. When I push the button on nothing happens. I think I need a new motor- just want to make sure before I spend the money.[/quote:e97ea663e7]
Motor it is indeed just did one 2day
But I will add check the windshield washer pump also
U may need a new one or the wires had pulled out or check the supply hose it may be cut
Good luck
Nov 28, 2007 at 8:59 AM
