Can you tell me where the torque converter is located on a 1993 ford taurus 3.8L V6 automatic?
Jun 9, 2007 at 6:26 AM
The torque converter is between the engine and transmission, bolted to the flexplate on the crankshaft, with the transmission input shaft inserted into its center. On some vehicles it can be seen through an inspection cover on the transmission bellhousing.
The owner asked where the torque converter is located on a 1993 Ford Taurus 3.8L V6 automatic. The expert explained it sits between the engine and transmission, bolted to the flexplate and crankshaft, with the transmission shaft slid into the middle, and may be visible through a bellhousing inspection cover.
