Its an internal tranny issue
and I would suspect tranny oil pump (very common )
and since tranny need to come out for the pump (if test should its the pump )
rebuilding the tranny should be a must since its all out,
to quickly check the links
E. Brake ON
engine off place
key on make sure your foot on the brakes at all times
place shifter in R and try to start
and try it in D too
if it start in any other position then P and N
you have links issue (I doubt that )
I do suspect internal tranny failure and tranny oil pump
SPONSORED LINKS
Thursday, January 21st, 2010 AT 6:27 AM
