2001 Ford Taurus Overheats Then Won't Start
GABBYNIK
My 2001 Ford Taurus overheated on the highway. Got off the highway and turned car off. Car then would not start. 4 days later, car started sluggishly. Used a trailer to haul the car home. Now after 3 more days, car won't start again. It cranks but won't start. I am pretty sure it is the head gasket. Does this sound correct? Why won't the car start now?
Nov 8, 2007 at 5:05 AM
  • 75,988 POSTS
Pull all the sparkplugs out and inspect for water in the cylinders and inspect the plugs.
Also check for spark-disconnect a plugwire or 2 and ground it to the engine-while cranking it over-do you have spark? If you got spark look for fuel
Pressure test it to confirm its the headgasket-
Nov 8, 2007 at 5:26 AM
Suggested Repair
Remove and inspect the spark plugs for water in the cylinders. Check for spark while cranking, then check fuel if spark is present. Pressure-test the cooling system to confirm whether the head gasket has failed.
Conversation Summary
A 2001 Ford Taurus overheated on the highway and then would not start. It started sluggishly days later, was trailered home, and now cranks but will not start. The owner suspects a head gasket. The expert advised inspecting the plugs for water, verifying spark and fuel, and pressure-testing to confirm a head gasket problem.
