1994 Ford Taurus Idle Surge and Smoke
Suggested Repair
Scan for stored fault codes when the MIL comes on. Check the exhaust for a coolant odor and have a leakdown test done to evaluate a possible head gasket problem. Do not replace parts such as the CCRM without test results showing they are faulty.
Conversation Summary
A 1994 Ford Taurus 3.8L starts and initially idles normally, then the MIL comes on with a high idle, sputtering, dark smoke, and carbon or rust from the exhaust. The MIL later goes off and idle drops. White smoke is also reported, and restarting after a short drive can cause surging and a rough idle. Replacing the CCRM did not help. Experts advised retrieving the stored fault codes, checking the white smoke for a coolant smell, and considering a leakdown test because a head gasket problem is possible. They also cautioned against replacing parts without evidence they are bad.
