Replacing Front Wheel Bearing Assembly what the torque specs?
MSPENCER
Could you tell me what the torque specs are for replacing the front wheel bearing assembly on a 2002 Ford Taurus SES, 6 cyl. DOHC, mileage approx. 100K
Aug 5, 2007 at 2:16 AM
  • 55,549 POSTS
The torque specs are 70 foot pounds. Here is a guide to show you what you are in for when doing the job.
https://www.2carpros.com/articles/bearing-hub-replacement
Here is a diagram to show you what replacement the wheel bearing hub is on your car (below)
You will need a jack and jack stands to raise the car up safely.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Cheers, Ken
Nov 10, 2017 at 4:24 AM
