2003 Ford Taurus CV Joint Replacement
CLISHMAN67
I have a 2003 Ford Taurus with 89231 miles. I need to replace the cv joints and want to know if there is anything special I should be aware of. I have a generic instruction, but need to know if there are special torq or special tools or things that I need to watch out for with a Taurus
Thank you!
Jun 23, 2007 at 2:41 AM
SQM
  • 6,383 POSTS
There are a few specials tools that need to be used to finish this job.
Primarily you will need a hub puller and a slide hammer tool. Most of these are typically available at your local auto parts store that can be rented to use.
Here is a helpful guide on CV axle replacement:
https://www.2carpros.com/articles/replace-cv-axle
I have attached the replacement instructions as well as the tools required and all the torque specifications below.
Dec 14, 2021 at 1:54 AM
Suggested Repair
Rent a hub puller and slide hammer to replace the CV axles, and follow the service guide and listed torque specifications.
Conversation Summary
The owner of a 2003 Ford Taurus with about 89,000 miles asked whether CV joint replacement requires special tools, torque values, or other precautions. The expert said a hub puller and slide hammer are needed, noted that they can usually be rented, and directed the owner to a CV axle guide with replacement instructions and torque specifications.
