1994 Ford Taurus Starter Stays Engaged
JASONY
  • 5 POSTS
1994 Ford Taurus 3.8. Wouldn't start, no click or anything so I checked battery/cables/terminals - all good and plenty of juice. Put test light to positive line to starter and turned ignition. Lighted turned on and off as I turned the ignition on and off so I didn't think it was the ignition. Replaced starter. Started right up and I drove it around a mile or so. Everything A-okay.
Next day driving down freeway and heard a grinding sound, like an axe on a grinding wheel. Smelled something burning. Tried turning car off but it wouldn't turn off and starter wouldn't disengage. Starter finally quit as it fried, but burning smell continued. Disconnected positive battery cable to stop the car. I believe I wired the new starter correctly as options are limited by post size and ground wire length. Tempted to try another starter but before sinking another $128 into it I'm curious if maybe it is something other than the starter. Any ideas or suggestions?
Thanks!
Sep 1, 2007 at 10:56 AM
  • 75,988 POSTS
[quote:79efeccbc5="jasony"]Hello,
Thanks![/quote:79efeccbc5]
Sir
You need to investigate the starter relay and ignition switch when they sticking it will do that.
Sep 1, 2007 at 11:15 AM
Suggested Repair
Inspect the starter relay and ignition switch for sticking, which can keep the starter engaged while driving and damage it.
Conversation Summary
A 1994 Ford Taurus 3.8 would not crank. After the starter was replaced, it started and drove normally, then later stayed engaged on the freeway, ground, burned, and would not shut off until the battery cable was disconnected. The expert advised checking the starter relay and ignition switch for sticking rather than immediately replacing the starter again.
