1996 Ford Taurus Starter, selinoid, or other electrical cir
ISAIAS
  • 1996 FORD TAURUS
  • 6 CYL
  • 170,000 MILES
We changed the bake master cylinder but now the car won't start it doest even attemp to turn on and there is no cliking nosie coming from selinoid. The battery is new please help. If u can help me I will be glad to donate.
Thursday, September 9th, 2010 AT 12:39 PM
  • 109,885 POSTS
Did this just start since the master cylender was replaced?
Thursday, September 9th, 2010 AT 12:45 PM
ISAIAS
Yes it all started after we replaced the master cylinder and brake booster. I cheack all the fuses they are good.
Sunday, September 12th, 2010 AT 10:57 PM
  • 109,885 POSTS
I need you to recheck your work under the dash to make sure nothing was disconnected. Also, check under the hood to make sure nothing was accidentally disconnected by the booster. There are major wiring harnesses that go through the firewall at that point. Check to make sure they are tight and clean.
Monday, September 13th, 2010 AT 11:14 AM
