Remove Steering column
FORD TAURUS
ABBYSPIKEOOX
I have a Ford Taurus 2003. I need to remove the steering column. A step by step would be good. But any advice would be Appreciated. Thank You
Nov 18, 2007 at 8:27 AM
MERLIN2021
  • 17,250 POSTS
Disconnect negative battery cable and wait 2 mins to deactive the air bags. Unplug connectors Look at the bottom of the column, undo the small U-Joint, then unbolt the column at the brackett, unhook the indicator wire. Then pull out the column.
Nov 18, 2007 at 8:31 AM
