1995 Ford Taurus Sticky Pedal Laboring
The car will run a little rough for a minute or so but smooth out. There is no such thing as "lubing" the throttle cable. There is a black builkup of fuel additives in the throttle body.
I would change the plugs, fuel filter, oil and air filters. Replace the bad filler neck and get on with it. At this stage i don't think a flush is necessary. A lot of times it a rip off.
Remember, back to basics.
Good luck
I already replaced the plugs, air filter, fuel filter, and my last oil change and filter was only 1500 mi's ago. I also had a fuel induction done two months ago. I just want to know if I could harm the car by having a fuel injection flush done before replacing the filler neck.
If you put a good grade of injector cleaner in your gas about 3 times a year, especially in the spring and late fall, it will help your vehicle performance. Good luck
Suggested Repair
Clean the throttle body by removing the intake duct and brushing both sides of the throttle plate and bore with carburetor cleaner. Another fuel-injection flush is not necessary after a recent induction service and is unlikely to fix the sticking pedal. Replace the rotted fuel filler neck when the part arrives, and use a quality injector cleaner in the fuel a few times a year.
Conversation Summary
The owner of a 1995 Ford Taurus with 117,000 miles reported a sticking accelerator pedal and laboring under acceleration. A dealer suggested a fuel-injection flush and throttle-body lubrication, but the owner also needed a rotted fuel filler neck that the dealer said was unavailable. The expert said throttle-cable lubrication is not a real service and attributed the problem to additive buildup in the throttle body. They recommended cleaning the throttle plate and bore, skipping another flush because one is typically needed only about every 30,000 miles, and replacing the filler neck. The owner had already replaced the plugs, air filter, and fuel filter, had a recent oil change, and had a fuel induction service two months earlier. The expert confirmed a mechanic can clean the throttle body and suggested periodic injector cleaner.
