1992 Ford Taurus Input voltage to Throttle position sensor
220,000 MILES • 6 CYL • FWD • AUTOMATIC
JERRYMAC3139
What is the voltage suppose to be at terminal #47 of the eec. It goes to the throttle position sensor.
Oct 1, 2009 at 11:49 AM
JGAROFALO
  • 489 POSTS
[quote:9b0a94c349="jerrymac3139"]Electrical problem
1992 Ford Taurus 6 cyl Front Wheel Drive Automatic 220000 miles
What is the voltage suppose to be at terminal #47 of the eec. It goes to the throttle position sensor.[/quote:9b0a94c349]
Oct 2, 2009 at 2:04 PM
JGAROFALO
  • 489 POSTS
[quote:e04a59f033="jerrymac3139"]Electrical problem
What is the voltage suppose to be at terminal #47 of the eec. It goes to the throttle position sensor.[/quote:e04a59f033]
Voltage at that pin will vary based on the throttle opening. It should be from about .75 to 1.0 volts at closed throttle, and will rise to 5.0 volts at wide open throttle.
Oct 2, 2009 at 2:05 PM
