High speed shaking
TRUCKGUY300
:?: I have a 1992 Ford taurus 3.0L GL. on the highway at exactly 67-77 mph the car violently shakes. It has been checked out and has new axles,tierods,bearings,etc. This has calmed it down alot but still shakes. Also has been aligned, new tires and balanced. The shake feels like it moves the car up and down, enough to make the dashboard visibly shake.
Any ideas? :?: :?
Jan 19, 2006 at 8:47 AM
10FOTUCK
  • 28 POSTS
If it is rear wheel drive put it in neutral chalk the tire so it dont roll and check your driveline and U-joints. If front wheel drive check your CV joints. If all that is ok then you may have a tire seperating you may have to have tires rotated to see if that makes a difference.
Jan 20, 2006 at 6:03 AM
