1992 Ford Taurus Pop When Turning
BMXKIDA879
hello i have a 1992 ford Taurus SHO with 127,000 miles on it with the 3.0 liter DOHC engine, when i turn at slow speeds my car makes a pop, and sometimes a creak, can you help me out?
May 7, 2007 at 4:26 PM
SERVICE WRITER
  • 9,123 POSTS
If you are not moving and turn the wheel, will it do it then?
May be the spring or strut bearing moving.
IF you open the hood and have someone outside of the car listening, they may be able to further narrow down the source.
May 7, 2007 at 10:00 PM
BMXKIDA879
yea if im not moving it makes the sounds too, someone told me it was the sway bar end caps but i have no clue with these front wheel drive cars.
May 8, 2007 at 2:46 PM
SERVICE WRITER
  • 9,123 POSTS
May be the spring or strut bearing moving. Broken spring perhaps. IF you open the hood and have someone inside the carturning the wheel back and forth slowly, you may be able to further narrow down the source by listening and watching for noise as it happens.
https://images.2carpros.com/forum/automotive_pictures/30961_strut_1.jpg
In particular, place your hand on the strut tower in the engine compartment and feel if it is prominent at that point. There wa a TSB that reflected the Upper Spring seat assembly rubbing on the Sheet metal tower. Basically it called for a spacer being put in. IF it were me and I'm pulling it out , I would install new Monroe Quick-strut assys.
https://images.2carpros.com/forum/automotive_pictures/30961_qstrut_1.jpg
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=MON&MfrPartNumber=171780&PartType=49&PTSet=A sway bar end caps ? new one on me.
May 9, 2007 at 10:03 PM
Suggested Repair
With the hood open, have someone turn the wheel slowly and feel the strut towers for the pop or creak. Suspect a worn strut bearing, broken spring, or upper spring seat rubbing the tower (a TSB called for a spacer). If the strut is removed, install new Monroe Quick-Strut assemblies.
Conversation Summary
A 1992 Ford Taurus SHO with 127,000 miles pops and sometimes creaks when turning at slow speeds, including when the car is not moving. The owner was told it might be sway bar end caps. The expert said the noise may be a moving spring or strut bearing, possibly a broken spring, and suggested listening and feeling the strut tower while the wheel is turned. A TSB covered the upper spring seat rubbing the sheet-metal tower and called for a spacer; the expert recommended new Monroe Quick-Strut assemblies if the strut is removed and did not recognize sway bar end caps as the cause.
