Ford Taurus SHO stranded - Will not start - Fuel Pump good
WBIRDWELL
1994 Ford Taurus SHO - 135,000? - V6 3.2 - Auto
About 10 days ago I had to really pump the gas to start it (not normal for this car). And the gas guage read empty until I started driving it and it very slowly went up to the correct fuel level.
Now it will not start by pumping the gas. One nice person was able to spray stuff directly under the hood and it started and idled. When I let off of the gas it died. I don't know if I had kept giving it gas if it would have finally kept going. We stopped.
A mechanic walked down and checked to see if it was the fuel pump. He said it was working. However the injectors were not getting gas.
Why? That is the question. What can I do or have checked to get my wonderful car going again?
The only thing known wrong is that the alternator bearings make a lot of noise and it needs to be rebuilt. Been getting worse for about 2 years. Just figured out where the noise was coming from.
The only code is 332 (Insufficient EGR flow).
I think it has had that one for years. So I don't think it is related to not starting. But I never know so I thought I would mention it.
Also, it had recently failed emmissions for the first time.
HC...508... Limit... 220
Co...1.91...Limti...1.20
CO2...13.38...Passed
If you can figure this out you are better than most!
Thanks for trying!
Nov 13, 2007 at 3:12 PM
  • 75,988 POSTS
Get the alternator up to par and do a fuel pressure check and comeback with the readings.
About the EGR it will prevent the car from starting or it will not stay running.
Your HC reading being High see below.
Hydrocarbon failures mean unburned gasoline is passing through the engine and entering the exhaust. The three most common causes include ignition misfire, lean misfire and low compression (typically a burned exhaust valve). Ignition misfire can be caused by worn or fouled spark plugs, bad plug wires or a weak coil. Lean misfire results where there is too much air and not enough fuel, so check for vacuum leaks, dirty injectors or a fuel delivery problem. In addition to these, hydrocarbon failures can also be caused by oil burning due to worn valve guides, valve guide seals and/or rings.
BTW we're the worlds best in automotive servicing Team 2carpros
Nov 13, 2007 at 9:21 PM
  • 75,988 POSTS
[quote:fba26a1942="rasmataz"]Get the alternator up to par and do a fuel pressure check and comeback with the readings.
HC and CO are high, the vehicle may have a bad catalytic converter or an air pump problem see below.
Carbon monoxide failures indicate an overly rich fuel mixture. On older carbureted engines without electronic feedback controls, look for things like a stuck choke, misadjusted or fuel saturated float or a rich idle mixture adjustment. On newer vehicles with electronic carburetors or fuel injection, the system may not be going into closed loop because of a bad coolant or oxygen sensor.
BTW we're the worlds best in automotive servicing Team 2carpros[/quote:fba26a1942]
Nov 13, 2007 at 9:28 PM
