Ford Taurus Door Lock problems
CHAMMAMA
Hi
I have ford taurus se 1999 model. Suddenly my driver side door lock/unlock stopped working with remote and inner lock/unlock switch. But it locks and unlocks with the key. All other door lock/unlock works fine with remote and inner lock/unlock switch. I could hear some parts loosen noise near the driver door. But the driver side lock makes click noise but doesn't actually lock/unlock with the remte and inner lock/unlock switch. What could be reason for this failure. This problem I saw when my daughter was pulling the driver side lock from outside when I was trying to unlock the doors using remote. How do I fix this problem myself.
Thanks
Chandra
Mar 20, 2006 at 1:55 AM
RAYHUT
  • 134 POSTS
you might need to go have this fixed. you have a little remote box inside your door that reads your key remote,and it could have gone bad.so i highly recommend that you take it to a mech.to replace it.don't think i'm saying that couse your a woman it's that you start messing with things like that and you could do other damage.
Mar 20, 2006 at 8:44 PM
