94 ford taurus power door locks don't work
DEEDLEGIZZ
I bought a beautiful 94 ford taurus loaded, almost everything works. I cannot figure out the power door locks. i did not get a keyless entry remote for the vehicle at the time i bought it. the power door locks from the driver or passenger side do not work. i have checked the fuses and the switch does work it was checked by meter but don't know where to check now. Didn't know if there are relays to check and where they might be located. It makes it a little hard to get across the car to lock or unlock from drivers side with leg brace on. any suggestions are appreciated. DeedleGizz
Jan 22, 2006 at 7:30 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Provide the recorded switch-test findings and clarify whether any lock movement or sound had been observed during the failures.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
NAPAGUY
  • 14 POSTS
If the master switch is ok (drivers door) and you have checked the wires for continuity, then replace the actuator in the other door. Each door has its own actuator.
Jan 22, 2006 at 12:05 PM
KONG
Hi, if your car has a key fob try turning the key in the ignition off and on 8 times. Don't turn the key all the way for the car to start. The locks should pop and down by themselves and then press any button the key fob a few times. I usually press the lock button.
good luck.
Nov 21, 2007 at 6:54 AM
Discussion summary
The owner of a 1994 Ford Taurus reported that the power door locks did not work from either the driver or passenger side. The owner had no keyless remote and reported checking the fuses and checking a switch with a meter.
Reported outcome: The owner did not report a completed repair or resolution.
The meter readings and exact scope of the switch check were not supplied. A reply suggested an actuator, but no findings confirmed a failed component. A separate remote-programming suggestion did not address the owner’s stated lack of a remote.
Read the original discussion
