2003 Ford Taurus Window Won't Go Up
TDC94
The driver side window on a 2003 ford taurus will not come back up. There is a clcking noise coming from under the dash by the door.
Jan 5, 2007 at 3:41 AM
BOOTDOG
  • 665 POSTS
whats probably happend is the teeth on the widow motor is stripped out. pulling out the widow regulator to change the motor can be tricky. if you plan on doing this yourself, buy a manuel to show you step by step on replacement.
Jan 5, 2007 at 10:22 PM
Suggested Repair
The window motor teeth are likely stripped. Replace the window motor; removing the regulator can be tricky, so use a repair manual for the step-by-step procedure.
Conversation Summary
The driver-side window on a 2003 Ford Taurus will not go back up, and there is a clicking noise under the dash near the door. The expert said the window motor teeth are probably stripped and recommended replacing the motor with a repair manual because regulator removal can be difficult.
